HP Officejet Pro 8600 Plus Power Source Adapter Replacement
  1. HP Officejet Pro 8600 Plus Power Source Adapter Replacement, Power Source Adapter: step 1, image 1 of 2 HP Officejet Pro 8600 Plus Power Source Adapter Replacement, Power Source Adapter: step 1, image 2 of 2
    • Turn the printer so the back is facing you.
    • Put the printer in a vertical position by lifting its right side.
  2. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 2, image 1 of 1
    • Remove the two 12mm-T10 Torx screws on the top edge of the printer.
  3. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 3, image 1 of 1
    • Rotate the printer clockwise so the bottom of the printer is facing you.
  4. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 4, image 1 of 2 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 4, image 2 of 2
    • Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel.
    • Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
    • This step requires applying a significant amount of force on the left notch. Don't be alarmed if you hear popping noises.
  5. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 5, image 1 of 1
    • Remove the side panel from the printer by lifting upwards toward you.
    • For reassembly, slide the side panel from left to right into place.
  6. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 6, image 1 of 3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 6, image 2 of 3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 6, image 3 of 3
    • Rotate the printer to its standard position.
  7. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 7, image 1 of 3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 7, image 2 of 3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 7, image 3 of 3
    • Unplug the black wire with the white cap connecting the power supply to the motherboard.
  8. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 8, image 1 of 1
    • Remove the two 12mm-T10 Torx screws from the base of the power supply mount.
  9. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 9, image 1 of 2 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 9, image 2 of 2
    • Place your left hand on the left side of the power supply through the opening in the side of the printer.
  10. HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 10, image 1 of 3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 10, image 2 of 3 HP Officejet Pro 8600 Plus Power Source Adapter Replacement: step 10, image 3 of 3
    • Grab the base of the cable on the right side of the power supply with your right hand.
    • Remove the power supply by pulling your right hand toward you and pushing your left fingers toward you.
9 other people completed this guide.
Karissa Roof
223 Reputation
1 Guide authored
Cal Poly, Team S16-G4, Livingston Spring 2018 Member of Cal Poly, Team S16-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G4
4 Members
10 Guides authored
3 Comments
I have used this guide to replace the power supply for my Officejet 8715. The only difference is a third screw that needs to be removed to take the cover off.
This is an easy repair.
The real challenge is to find the right replacement part. The power supply is used in various models.
The OEM Number of the power supply is E3E01-60132
I have paid for this spare part less than 30€. Worthwhile as a new printer costs around 300€.
Bernhard Keim - Reply
Does the 8600 P/S fit on the 8620? If not, what is part nr for 8620?
albert venter - Reply
Un peu galère dommage que j'ai pas trouvé se blog avant car a par les visse chiant à défaire c'est bien expliquer après essai du fusibles en porcelaine jus arrive et rien derrière donc merci
coin coin lecanard - Reply
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 64
All Time: 6,223
