HP Officejet Pro 8620 CMOS Battery Replacement
  1. HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: step 1, image 1 of 3 HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: step 1, image 2 of 3 HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: step 1, image 3 of 3
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
  2. HP Officejet Pro 8620 CMOS Battery Replacement: step 2, image 1 of 2 HP Officejet Pro 8620 CMOS Battery Replacement: step 2, image 2 of 2
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 CMOS Battery Replacement: step 3, image 1 of 2 HP Officejet Pro 8620 CMOS Battery Replacement: step 3, image 2 of 2
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 CMOS Battery Replacement: step 4, image 1 of 3 HP Officejet Pro 8620 CMOS Battery Replacement: step 4, image 2 of 3 HP Officejet Pro 8620 CMOS Battery Replacement: step 4, image 3 of 3
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
  5. HP Officejet Pro 8620 CMOS Battery Replacement, CMOS Battery: step 5, image 1 of 1
    • Gently bend the black ribbon cable by using your left hand.
    • Remove the 8mm T9-Torx screw under the black plastic cover by turning counter clockwise.
  6. HP Officejet Pro 8620 CMOS Battery Replacement: step 6, image 1 of 2 HP Officejet Pro 8620 CMOS Battery Replacement: step 6, image 2 of 2
    • Gently move the black plastic cover to the side by using your right hand.
    • Place one finger behind the top of the motherboard where you removed the previous screw.
    • Gently pull the motherboard towards you by about an inch by using your right hand's finger.
  7. HP Officejet Pro 8620 CMOS Battery Replacement: step 7, image 1 of 1
    • Gently remove the CMOS battery by using a finger from your left hand, while holding the motherboard with your right hand.
5 other people completed this guide.
Michael
331 Reputation
1 Guide authored
Cal Poly, Team S19-G2, Livingston Winter 2018 Member of Cal Poly, Team S19-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G2
3 Members
8 Guides authored
3 Comments
I removed the lithium CMOS 3 volt battery, connected 2 wires at +(red) and - (black). Open a hole at plastic cover, and now I’m using 2 AA in serial, in a holder externally. To refill the cartridges , first open the cover till carriage stops in the middle. Second disconnect the 120 V power cable. Third remove the external CMOS 2 AA batteries, from the holder . Forth remove ink cartridges, refill and install them in the carriage. Insert exterior CMOS 2 AA batteries in the holder, Connect the power cable and you are good to go.
Arbaches Glaukus - Reply
I removed all the board fasteners to be sure. That small metal hook down below your right thumb. Be careful there no to damage the board. 10 minutes and done!
servehimdaily - Reply
Apparently the screws are T10 not T9. T9 works but you'll slightly damage the screw.
dbovey - Reply
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 118
All Time: 11,517
