HP Officejet Pro 8620 Display Replacement
  1. HP Officejet Pro 8620 Display Replacement, Display: step 1, image 1 of 2 HP Officejet Pro 8620 Display Replacement, Display: step 1, image 2 of 2
    • Place the printer on its back and rotate the display clockwise to gain access to the underside of the display.
  2. HP Officejet Pro 8620 Display Replacement: step 2, image 1 of 3 HP Officejet Pro 8620 Display Replacement: step 2, image 2 of 3 HP Officejet Pro 8620 Display Replacement: step 2, image 3 of 3
    • Locate the control arm on the underside of the display. You will need to detach this to access the screws.
    • Place a finger behind the control arm.
    • Separate the display unit from the control arm by pulling down with your finger and using your other hand to push the display unit up.
    • Removing the control arm takes a moderate amount of force.
  3. HP Officejet Pro 8620 Display Replacement: step 3, image 1 of 3 HP Officejet Pro 8620 Display Replacement: step 3, image 2 of 3 HP Officejet Pro 8620 Display Replacement: step 3, image 3 of 3
    • Remove the four 11mm T9-Torx screws on the underside of the display unit by rotating the screwdriver counter clockwise.
    • Open the display unit to expose the circuit board by separating the back and front panels.
    • Remove the ribbon cable by gently releasing the plastic locking mechanism and pulling the cable away from the circuit board.
  4. HP Officejet Pro 8620 Display Replacement: step 4, image 1 of 2 HP Officejet Pro 8620 Display Replacement: step 4, image 2 of 2
    • Remove the four 7mm T9-Torx screws from the circuit board that are holding the screen in place using a T9-Torx screwdriver and turning counter clockwise.
    • Lift the circuit board/screen panel from the black frame.
4 other people completed this guide.
Dallas Rocha
243 Reputation
1 Guide authored
Cal Poly, Team S19-G2, Livingston Winter 2018 Member of Cal Poly, Team S19-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G2
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 21
All Time: 5,176
