Introduction
The left panel gives access to a variety of parts, Including the Motherboard, CMOS Battery, Power Brick and several others.
You will need a T9-Torx Screwdriver for this project.
It is recommended that you organize the screws using a magnetic white board or your preferred method.
Turn off the printer and remove the power cable.
Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
