HP Omen 15-5002xx Battery Replacement
  1. HP Omen 15-5002xx Battery Replacement, Back Cover: step 1, image 1 of 2 HP Omen 15-5002xx Battery Replacement, Back Cover: step 1, image 2 of 2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Battery Replacement, Battery: step 2, image 1 of 1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Battery Replacement: step 3, image 1 of 2 HP Omen 15-5002xx Battery Replacement: step 3, image 2 of 2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
Eduardo Arellano
621 Reputation
5 Guides authored
Gateway, Team 1-1, Saknee Fall 2021 Member of Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 574
