This guide will show you how to replace the battery in an HP Omen 16 laptop. There are clear signs when a laptop battery needs to be replaced. Battery life can be noticeably decreased, charging can be very slow, or the laptop randomly shuts down. If you are experiencing any of these signs, it might be time to replace your battery.
Use the flat end of a spudger to pull the right edge of the 12 pin connector towards you. Repeat this same action to the other side of the connector and do so until it is completely free.
Warning: Do not try to pull one side completely free without also pulling the other side. This could break the delicate wire connectors and render the battery unusable.
Place the bottom of the chassis back onto the laptop and push down on each corner of the laptop until you hear a snap or it is clear that the case has been resealed.
