HP Omen Desktop PC Disassembly
  1. HP Omen Desktop PC Disassembly, Preparation: step 1, image 1 of 1
    • Prepare a large workspace.
    • Save all work and shut down the computer.
    • Unplug all cables from the back of the computer, including the power cable.
  2. HP Omen Desktop PC Disassembly, Removing the Right Panel: step 2, image 1 of 2 HP Omen Desktop PC Disassembly, Removing the Right Panel: step 2, image 2 of 2
    • Press the button on the back of the chassis labeled Internal Access. The side panel should come off.
    • Lift up and out to remove.
    • Make sure to store the side panels somewhere safe and out of the way.
  3. HP Omen Desktop PC Disassembly, Remove the Left Panel: step 3, image 1 of 2 HP Omen Desktop PC Disassembly, Remove the Left Panel: step 3, image 2 of 2
    • Unscrew this screw.
    • Slide the panel backwards against the case, and pull up.
  4. HP Omen Desktop PC Disassembly, Removing the Hard Drives: step 4, image 1 of 2 HP Omen Desktop PC Disassembly, Removing the Hard Drives: step 4, image 2 of 2
    • Unplug these two cables.
    • Squeeze the two tabs on either side of the bay, and pull it out.
  5. HP Omen Desktop PC Disassembly, Remove the GPU Brackets: step 5, image 1 of 3 HP Omen Desktop PC Disassembly, Remove the GPU Brackets: step 5, image 2 of 3 HP Omen Desktop PC Disassembly, Remove the GPU Brackets: step 5, image 3 of 3
    • Unplug these cables and let them hang to the side.
    • Remove this screw, and lift up the bracket holding the graphics card in place.
    • Unscrew these two screws at the other end of the graphics card.
    • These screws can be difficult to remove. If they do not come out when twisted, push on the other side of the screw while unscrewing.
  6. HP Omen Desktop PC Disassembly, Remove the GPU: step 6, image 1 of 1
    • Push down on this latch behind the graphics card.
    • Pull firmly on the graphics card until it comes out.
  7. HP Omen Desktop PC Disassembly, Unplug the Motherboard Cables: step 7, image 1 of 3 HP Omen Desktop PC Disassembly, Unplug the Motherboard Cables: step 7, image 2 of 3 HP Omen Desktop PC Disassembly, Unplug the Motherboard Cables: step 7, image 3 of 3
    • Unplug each of these cables from the motherboard:
    • System Fan Header & 4-Pin CPU Power
    • LED, Power Button, & LED Strip
    • Front USB Ports
    • Hard Drive 1 & 2
    • 24-Pin Power
    • Front HD Audio
    • Unscrew this screw at the bottom of the motherboard and remove the WiFi module. Be careful of the antenna that are wired to the module, as they are fragile.
  8. HP Omen Desktop PC Disassembly, Remove the Motherboard: step 8, image 1 of 3 HP Omen Desktop PC Disassembly, Remove the Motherboard: step 8, image 2 of 3 HP Omen Desktop PC Disassembly, Remove the Motherboard: step 8, image 3 of 3
    • Unscrew these 8 screws.
    • Carefully remove the motherboard, holding it by the fan of the CPU cooler.
  9. HP Omen Desktop PC Disassembly, Remove the RAM: step 9, image 1 of 2 HP Omen Desktop PC Disassembly, Remove the RAM: step 9, image 2 of 2
    • Push down on these two tabs. The RAM module should come loose.
    • Pull it out.
  10. HP Omen Desktop PC Disassembly, Remove the SSD: step 10, image 1 of 2 HP Omen Desktop PC Disassembly, Remove the SSD: step 10, image 2 of 2
    • The SSD should pop up. Pull it out of the socket.
  11. HP Omen Desktop PC Disassembly, Remove the CPU Cooler: step 11, image 1 of 3 HP Omen Desktop PC Disassembly, Remove the CPU Cooler: step 11, image 2 of 3 HP Omen Desktop PC Disassembly, Remove the CPU Cooler: step 11, image 3 of 3
    • Remove this header for the CPU fan.
    • Remove these 4 torx screws and pull the cooler off of the CPU.
    • Make sure that the thermal compound does not touch any other parts of the motherboard when removing.
    • Flip the motherboard over and pull off the backplate.
    • The backplate is glued in, so use a scraper or knife to slowly remove the adhesive material from back of the motherboard.
    • The CPU and CPU socket are very fragile. Do not remove the CPU unless you have to.
    • Press down on the retention arm to the right of the CPU socket. Move it to the right, and then slowly release.
    • Bring it up and back until the CPU bracket flip out. Carefully remove the CPU from the socket.
    • DO NOT touch the inside of the socket! There are hundreds of small pins, and if even one of them is bent, the motherboard will no longer work.
    • If you are installing a new cooler or CPU, it is best to clean off the thermal paste using a paper towel and rubbing alcohol.
  12. HP Omen Desktop PC Disassembly, Removing the Power Supply: step 13, image 1 of 2 HP Omen Desktop PC Disassembly, Removing the Power Supply: step 13, image 2 of 2
    • Unscrew these 4 screws at the back of the case.
    • Push down on this small bracket behind the PSU.
    • The PSU cables are routed all around the case. In order to full remove the PSU, you must find and remove each cable.
    • Never take apart the power supply itself. Even if it is unplugged, capacitors inside the unit can still hold fatal amounts of charge.
4 other people completed this guide.
Harry Mullin
347 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 27
Past 7 Days: 161
Past 30 Days: 623
All Time: 18,962
