HP Omni 10 Speaker Replacement
  1. HP Omni 10  Speaker Replacement, Battery: step 1, image 1 of 1
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10  Speaker Replacement: step 2, image 1 of 1
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10  Speaker Replacement: step 3, image 1 of 1
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10  Speaker Replacement: step 4, image 1 of 2 HP Omni 10  Speaker Replacement: step 4, image 2 of 2
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10  Speaker Replacement: step 5, image 1 of 2 HP Omni 10  Speaker Replacement: step 5, image 2 of 2
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
  6. HP Omni 10  Speaker Replacement, Micro Card Reader: step 6, image 1 of 1
    • Unscrew the two 3.3 mm screws using a 00 Phillip's head screwdriver.
  7. HP Omni 10  Speaker Replacement: step 7, image 1 of 1
    • Lift and remove micro card reader board.
  8. HP Omni 10  Speaker Replacement, Speaker: step 8, image 1 of 1
    • Unscrew the four 3.3 mm screws using a 00 Phillip's head screwdriver.
  9. HP Omni 10  Speaker Replacement: step 9, image 1 of 2 HP Omni 10  Speaker Replacement: step 9, image 2 of 2
    • Pull the black and white wire connector up to disconnect it.
  10. HP Omni 10  Speaker Replacement: step 10, image 1 of 2 HP Omni 10  Speaker Replacement: step 10, image 2 of 2
    • Pull the red and black wire connector up to disconnect it.
  11. HP Omni 10  Speaker Replacement: step 11, image 1 of 1
    • Lift the speaker set out of their sockets.
    • The speakers will also be attached via adhesive. They may be difficult to remove by hand.
  12. HP Omni 10  Speaker Replacement: step 12, image 1 of 1
    • Unhook the left speaker's connector wire to fully remove it from the device.
Alex Miller
345 Reputation
5 Guides authored
USF Tampa, Team 1-1, Leahy Fall 2016 Member of USF Tampa, Team 1-1, Leahy Fall 2016
USFT-LEAHY-F16S1G1
3 Members
10 Guides authored
One Comment
its order when i will get it please candly I request
Abdul Raheem - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 632
