HP Omni 120 Series Fan Replacement
  1. HP Omni 120 Series Fan Replacement, Remove rear cover: step 1, image 1 of 1
    • Flip the unit so that the screen faces down.
    • At each side, remove the Philips screw.
    • Separate the back cover from the bezel with a spudger, then pull like you're gonna go mad!
  2. HP Omni 120 Series Fan Replacement, Remove fan: step 2, image 1 of 2 HP Omni 120 Series Fan Replacement, Remove fan: step 2, image 2 of 2
    • Remove the two Philips screws securing the metal cover, and remove the cover.
    • Remove the three Philips screws of a different size than before that are securing the fan.
    • Trace the fan cable and remove the connector from the motherboard.
Joseph Sctbunio
7,416 Reputation
42 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,037
