HP Pavilion 11 x360 Motherboard Replacement
  1. HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: step 1, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: step 1, image 2 of 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: step 2, image 1 of 3 HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: step 2, image 2 of 3 HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: step 2, image 3 of 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Motherboard Replacement, Detach Cable: step 3, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement, Detach Cable: step 3, image 2 of 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Motherboard Replacement, Battery: step 4, image 1 of 1
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Motherboard Replacement: step 5, image 1 of 3 HP Pavilion 11 x360 Motherboard Replacement: step 5, image 2 of 3 HP Pavilion 11 x360 Motherboard Replacement: step 5, image 3 of 3
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Motherboard Replacement: step 6, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement: step 6, image 2 of 2
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Motherboard Replacement: step 7, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement: step 7, image 2 of 2
    • Remove the battery.
  8. HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: step 8, image 1 of 1
    • Remove the two 3mm screws with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Cable: step 9, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Cable: step 9, image 2 of 2
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
  10. HP Pavilion 11 x360 Motherboard Replacement, Remove Hard Drive: step 10, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement, Remove Hard Drive: step 10, image 2 of 2
    • Remove the three 3mm screws using the PH0 screwdriver.
    • Pull the hard drive slightly away from the connection to easily disconnect the hard drive cable from the motherboard.
    • Remove the hard drive.
  11. HP Pavilion 11 x360 Motherboard Replacement: step 11, image 1 of 1
    • Remove the four 3mm screws using the PH0 screwdriver.
  12. HP Pavilion 11 x360 Motherboard Replacement: step 12, image 1 of 3 HP Pavilion 11 x360 Motherboard Replacement: step 12, image 2 of 3 HP Pavilion 11 x360 Motherboard Replacement: step 12, image 3 of 3
    • Remove the two screws from the metal hinge on the power button side using the PH0 screwdriver.
    • One silver 4mm screw
    • One black 5mm screw
    • Lift up the hinge to remove the metal bracket underneath.
  13. HP Pavilion 11 x360 Motherboard Replacement: step 13, image 1 of 3 HP Pavilion 11 x360 Motherboard Replacement: step 13, image 2 of 3 HP Pavilion 11 x360 Motherboard Replacement: step 13, image 3 of 3
    • Remove one 3mm screw using the PH0 screwdriver from the metal hinge located on the power connector side of the computer.
    • Lift up the hinge with some force to remove the metal bracket underneath.
  14. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Wireless Card: step 14, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Wireless Card: step 14, image 2 of 2
    • Unscrew the two 3mm screws with the PH0 screwdriver.
    • Pull the wireless card out of its port to disconnect it from the motherboard.
  15. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: step 15, image 1 of 3 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: step 15, image 2 of 3 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: step 15, image 3 of 3
    • Push the black tab away from the hinge of the laptop.
    • After the black tab has been flipped, pull out the blue cable to disconnect the keyboard cable.
  16. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Webcam Cable: step 16, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Webcam Cable: step 16, image 2 of 2
    • Pull horizontally toward the hinge of the laptop to disconnect the webcam cable.
  17. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: step 17, image 1 of 3 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: step 17, image 2 of 3 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: step 17, image 3 of 3
    • Pull up on the black tabs to disconnect the display cable.
  18. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Power Button Board: step 18, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Power Button Board: step 18, image 2 of 2
    • Pull the cable horizontally away from the motherboard to disconnect the power button board cable.
  19. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Power Connector Cable: step 19, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Power Connector Cable: step 19, image 2 of 2
    • Pull the cable horizontally away from the motherboard to disconnect the power connector cable.
  20. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Speaker Cable: step 20, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Speaker Cable: step 20, image 2 of 2
    • Pull the cable horizontally away from the motherboard to disconnect the speaker cable.
  21. HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: step 21, image 1 of 3 HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: step 21, image 2 of 3 HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: step 21, image 3 of 3
    • Push the white tab up toward the hinge of the laptop.
    • Disconnect touch pad cable by pulling up and away from the motherboard.
  22. HP Pavilion 11 x360 Motherboard Replacement: step 22, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement: step 22, image 2 of 2
    • Lift up to remove the motherboard.
  23. HP Pavilion 11 x360 Motherboard Replacement: step 23, image 1 of 3 HP Pavilion 11 x360 Motherboard Replacement: step 23, image 2 of 3 HP Pavilion 11 x360 Motherboard Replacement: step 23, image 3 of 3
    • Push outwards on the two black tabs to pop the RAM up.
  24. HP Pavilion 11 x360 Motherboard Replacement: step 24, image 1 of 1
    • Remove the RAM.
  25. HP Pavilion 11 x360 Motherboard Replacement: step 25, image 1 of 2 HP Pavilion 11 x360 Motherboard Replacement: step 25, image 2 of 2
    • Lift up the heat sink to remove it from the motherboard.
10 other people completed this guide.
Emily
487 Reputation
1 Guide authored
Cal Poly, Team 19-9, Maness Winter 2015 Member of Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
4 Members
12 Guides authored
One Comment
La tarjeta madre soportara un intel core i5?
Rodolfo Giron - Reply
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 49
All Time: 10,821
