HP Pavilion 11-n010dx Bottom Case Replacement
  1. HP Pavilion 11-n010dx Bottom Case Replacement, Bottom Case: step 1, image 1 of 2 HP Pavilion 11-n010dx Bottom Case Replacement, Bottom Case: step 1, image 2 of 2
    • Use the nylon spudger to remove the rubber pads near the hinge for the screen. Then remove the screws under the pads.
    • Use Phillips #0 to remove four 9mm screws.
    • Use Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Bottom Case Replacement: step 2, image 1 of 3 HP Pavilion 11-n010dx Bottom Case Replacement: step 2, image 2 of 3 HP Pavilion 11-n010dx Bottom Case Replacement: step 2, image 3 of 3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Bottom Case Replacement: step 3, image 1 of 2 HP Pavilion 11-n010dx Bottom Case Replacement: step 3, image 2 of 2
    • Use the plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
Joseph Lintz
915 Reputation
5 Guides authored
USF Tampa, Team 11-5, Blackwell Fall 2016 Member of USF Tampa, Team 11-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 1,376
