HP Pavilion 11-n010dx Hard Drive Replacement
  1. HP Pavilion 11-n010dx Hard Drive Replacement, Battery: step 1, image 1 of 2 HP Pavilion 11-n010dx Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Hard Drive Replacement: step 2, image 1 of 3 HP Pavilion 11-n010dx Hard Drive Replacement: step 2, image 2 of 3 HP Pavilion 11-n010dx Hard Drive Replacement: step 2, image 3 of 3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion 11-n010dx Hard Drive Replacement: step 3, image 2 of 2
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. HP Pavilion 11-n010dx Hard Drive Replacement: step 4, image 1 of 1
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  5. HP Pavilion 11-n010dx Hard Drive Replacement: step 5, image 1 of 2 HP Pavilion 11-n010dx Hard Drive Replacement: step 5, image 2 of 2
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  6. HP Pavilion 11-n010dx Hard Drive Replacement: step 6, image 1 of 2 HP Pavilion 11-n010dx Hard Drive Replacement: step 6, image 2 of 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  7. HP Pavilion 11-n010dx Hard Drive Replacement: step 7, image 1 of 1
    • Remove the battery from your device.
  8. HP Pavilion 11-n010dx Hard Drive Replacement, Hard Drive: step 8, image 1 of 1
    • Use the Phillips #0 to remove the three 3mm screws holding the hard drive in place.
  9. HP Pavilion 11-n010dx Hard Drive Replacement: step 9, image 1 of 2 HP Pavilion 11-n010dx Hard Drive Replacement: step 9, image 2 of 2
    • Carefully lift the hard drive out of place using the tag.
  10. HP Pavilion 11-n010dx Hard Drive Replacement: step 10, image 1 of 3 HP Pavilion 11-n010dx Hard Drive Replacement: step 10, image 2 of 3 HP Pavilion 11-n010dx Hard Drive Replacement: step 10, image 3 of 3
    • Gently pull on the cable connector to disconnect the hard drive from your device.
5 other people completed this guide.
Joseph Lintz
915 Reputation
5 Guides authored
USF Tampa, Team 11-5, Blackwell Fall 2016 Member of USF Tampa, Team 11-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G5
3 Members
5 Guides authored
2 Comments
Thanks a lot Joseph ! Works well for the model 11-n000nf !
Nicolas - Reply
Thanks Joseph-I was able to get it open, disconnect the battery and ordered a new battery. We’ll see if this corrects the problem. Computer was sleeping for over a year. Thank you for your pictures and easy to follow instructions.
Beverlyn - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 5,570
