HP Pavilion 14 Notebook Battery Replacement
  1. HP Pavilion 14 Notebook Battery Replacement, Remove Enclosure: step 1, image 1 of 1
    • Unscrew the 5 P1 Philips screws (2 under the rubbers). You can esaily follow: HP official video to Remove the Base Enclosure
    • Once you pull up the sides of the cover (e.g. with a pick). You will feel it is still attached in the middle. You can squeeze your hand under the enclosure and push from the middle to liberate a clip in the middle of the enclosure. Pulling directly from the sides feels like the cover will break.
    • If you are not sure of the model of the computer/battery. you can do this step to check the battery model before buying it and then close it again doing the inverse.
  2. HP Pavilion 14 Notebook Battery Replacement, Replace Battery: step 2, image 1 of 2 HP Pavilion 14 Notebook Battery Replacement, Replace Battery: step 2, image 2 of 2
    • You can check the battery model (top-left of the battery), for our case HT03XL, with this reference you will be able to get the propper replacement.
    • If you have the replacement you can unscrew the 5 P1 Philips screws. The top part will have the connector you will need to disconnect to remove the battery. You can follow HP official video to remove the battery
    • Connect the new battery and screw again the 5 screws.
To reassemble the enclosure, clip it again and screw again the 5 screws (follow Step 1 instructions in reverse order).
Oriol CN
125 Reputation
1 Guide authored
One Comment
Nice explanation about the disassemble the hp notebook laptop. And replace the original battery replacement hp guide
Mahima Singh - Reply
Past 24 Hours: 4
Past 7 Days: 42
Past 30 Days: 151
All Time: 4,318
