HP Pavilion 14-bk061st Fan Replacement
  1. HP Pavilion 14-bk061st  Fan Replacement, Back Panel: step 1, image 1 of 2 HP Pavilion 14-bk061st  Fan Replacement, Back Panel: step 1, image 2 of 2
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st  Fan Replacement: step 2, image 1 of 1
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st  Fan Replacement: step 3, image 1 of 1
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st  Fan Replacement, Heat Sink: step 4, image 1 of 2 HP Pavilion 14-bk061st  Fan Replacement, Heat Sink: step 4, image 2 of 2
    • Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
  5. HP Pavilion 14-bk061st  Fan Replacement: step 5, image 1 of 1
    • Carefully grab the heat sink from any side and lift straight up while trying to avoid touching other components.
    • Avoid bending the heat-pipe at all costs to keep it functional.
  6. HP Pavilion 14-bk061st  Fan Replacement, Fan: step 6, image 1 of 1
    • Remove the three 2.9mm JIS #1 screws surrounding the fan.
  7. HP Pavilion 14-bk061st  Fan Replacement: step 7, image 1 of 2 HP Pavilion 14-bk061st  Fan Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully lift up the fan without tugging out the attached wire, and lay it on the motherboard.
    • Use tweezers to gently unplug the power connector wire.
    • Remove the fan from the laptop.
Stefano Lo Re
382 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 681
