HP Pavilion 14-bk061st Motherboard Replacement
  1. HP Pavilion 14-bk061st Motherboard Replacement, Back Panel: step 1, image 1 of 2 HP Pavilion 14-bk061st Motherboard Replacement, Back Panel: step 1, image 2 of 2
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Motherboard Replacement: step 2, image 1 of 1
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Motherboard Replacement: step 3, image 1 of 1
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Motherboard Replacement, RAM Card: step 4, image 1 of 1
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Use the hook end of the Halberd spudger to pull back the clamps holding the card in place.
    • Take care when pulling the second clamp as the card has a tendency to jump out.
  5. HP Pavilion 14-bk061st Motherboard Replacement: step 5, image 1 of 1
    • Remove the card by pulling it up and away from the slot.
  6. HP Pavilion 14-bk061st Motherboard Replacement, WLAN Card: step 6, image 1 of 2 HP Pavilion 14-bk061st Motherboard Replacement, WLAN Card: step 6, image 2 of 2
    • Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board.
  7. HP Pavilion 14-bk061st Motherboard Replacement: step 7, image 1 of 1
    • Remove the JIS #1 screw from the WLAN card.
  8. HP Pavilion 14-bk061st Motherboard Replacement: step 8, image 1 of 1
    • Remove the card by pulling it away from the slot.
  9. HP Pavilion 14-bk061st Motherboard Replacement, Heat Sink: step 9, image 1 of 2 HP Pavilion 14-bk061st Motherboard Replacement, Heat Sink: step 9, image 2 of 2
    • Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
  10. HP Pavilion 14-bk061st Motherboard Replacement: step 10, image 1 of 1
    • Carefully grab the heat sink from any side and lift straight up while trying to avoid touching other components.
    • Avoid bending the heat-pipe at all costs to keep it functional.
  11. HP Pavilion 14-bk061st Motherboard Replacement, Fan: step 11, image 1 of 1
    • Remove the three 2.9mm JIS #1 screws surrounding the fan.
  12. HP Pavilion 14-bk061st Motherboard Replacement: step 12, image 1 of 2 HP Pavilion 14-bk061st Motherboard Replacement: step 12, image 2 of 2
    Buy
    • Carefully lift up the fan without tugging out the attached wire, and lay it on the motherboard.
    • Use tweezers to gently unplug the power connector wire.
    • Remove the fan from the laptop.
  13. HP Pavilion 14-bk061st Motherboard Replacement, Motherboard: step 13, image 1 of 1
    • Remove the seven screws from the motherboard using a JIS #1 screwdriver.
  14. HP Pavilion 14-bk061st Motherboard Replacement: step 14, image 1 of 2 HP Pavilion 14-bk061st Motherboard Replacement: step 14, image 2 of 2
    • Remove the nine cables from the motherboard by carefully lifting the black tab on each connector.
  15. HP Pavilion 14-bk061st Motherboard Replacement: step 15, image 1 of 1
    • Carefully remove the motherboard from the casing.
3 other people completed this guide.
Mehrab Daemi
596 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 26
All Time: 938
