HP Pavilion 14-bk061st Screen Replacement
  1. HP Pavilion 14-bk061st Screen Replacement, Back Panel: step 1, image 1 of 2 HP Pavilion 14-bk061st Screen Replacement, Back Panel: step 1, image 2 of 2
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Screen Replacement: step 2, image 1 of 1
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Screen Replacement: step 3, image 1 of 1
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Screen Replacement, Screen: step 4, image 1 of 2 HP Pavilion 14-bk061st Screen Replacement, Screen: step 4, image 2 of 2
    • Remove the five JIS #1 screws that attach the hinges of the screen to the casing of the laptop.
  5. HP Pavilion 14-bk061st Screen Replacement: step 5, image 1 of 2 HP Pavilion 14-bk061st Screen Replacement: step 5, image 2 of 2
    • Carefully lift the hinges from the encasing and lift the bottom half of the laptop away from the screen.
  6. HP Pavilion 14-bk061st Screen Replacement: step 6, image 1 of 3 HP Pavilion 14-bk061st Screen Replacement: step 6, image 2 of 3 HP Pavilion 14-bk061st Screen Replacement: step 6, image 3 of 3
    • Use the metal spudger to carefully pry off the plastic encasing around the monitor.
    • Use the outside of the screen to remove the plastic encasing to avoid damaging the screen itself.
  7. HP Pavilion 14-bk061st Screen Replacement: step 7, image 1 of 2 HP Pavilion 14-bk061st Screen Replacement: step 7, image 2 of 2
    • Remove the four JIS #1 screws holding the screen in place.
  8. HP Pavilion 14-bk061st Screen Replacement: step 8, image 1 of 3 HP Pavilion 14-bk061st Screen Replacement: step 8, image 2 of 3 HP Pavilion 14-bk061st Screen Replacement: step 8, image 3 of 3
    • Carefully remove the sticker covering the wire that connects the screen to the motherboard.
    • Disconnect the cable that is connected to the screen.
  9. HP Pavilion 14-bk061st Screen Replacement: step 9, image 1 of 1
    • Remove the screen from the laptop.
Mehrab Daemi
596 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 26
All Time: 895
