HP Pavilion 14-cf0014dx RAM Replacement
  1. HP Pavilion 14-cf0014dx RAM Replacement, Back Panel: step 1, image 1 of 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx RAM Replacement: step 2, image 1 of 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx RAM Replacement, Battery: step 3, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx RAM Replacement: step 4, image 1 of 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx RAM Replacement, RAM: step 5, image 1 of 3 HP Pavilion 14-cf0014dx RAM Replacement, RAM: step 5, image 2 of 3 HP Pavilion 14-cf0014dx RAM Replacement, RAM: step 5, image 3 of 3
    • Using your fingers, simultaneously press the two silver clamps away from each other to release the RAM.
    • Each RAM stick will pop up at a 45 degree angle.
    • Remove the RAM from the device.
Sam Cole
813 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 13
All Time: 326
