HP Pavilion 14-cf0014dx SSD Replacement
  1. HP Pavilion 14-cf0014dx SSD Replacement, Back Panel: step 1, image 1 of 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx SSD Replacement: step 2, image 1 of 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx SSD Replacement, Battery: step 3, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx SSD Replacement: step 4, image 1 of 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx SSD Replacement, SSD: step 5, image 1 of 2 HP Pavilion 14-cf0014dx SSD Replacement, SSD: step 5, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the single screw securing the SSD to the motherboard.
  6. HP Pavilion 14-cf0014dx SSD Replacement: step 6, image 1 of 2 HP Pavilion 14-cf0014dx SSD Replacement: step 6, image 2 of 2
    • Carefully pull the SSD out of the slot.
Sam Cole
813 Reputation
7 Guides authored
One Comment
Hola!, ¿cómo es el cable para el SSD (Hard drive cable L23187-001), así como su case? (Hard drive cover L23219-001) La imagen que me aparece en la red del cable es muy largo. Gracias.
Ernesto P Mitre M - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 665
