HP Pavilion 14-n018us Display Assembly Replacement
Michael Hollister
Michael Hollister and 2 other contributors
Last updated on January 3, 2022
30 minutes
Moderate
Needs More Images
Introduction
Go to step 1
This guide is for the replacement of the display assembly of an HP Pavilion 14-n018us.
It will show the disassembly steps needed to remove and replace a laptop screen if it is broken or cracked without having to replace the entire laptop, saving money for the user.
Tools
Show more…
  1. HP Pavilion 14-n018us Display Assembly Replacement, Battery: step 1, image 1 of 2 HP Pavilion 14-n018us Display Assembly Replacement, Battery: step 1, image 2 of 2
    • Prior to removing the base plate, the battery must be removed.
    • Press the two tabs on the back of the laptop inward to release the battery.
    • Pull the battery straight out slowly and firmly.
  2. HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: step 2, image 1 of 3 HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: step 2, image 2 of 3 HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: step 2, image 3 of 3
    • Insert a plastic spudger into the groove around the laptop screen and gently loosen the plastic bezel away from the display.
    • Use the plastic spudger and loosen the display away from the back of the screen.
    • Continue to use the spudger to detach the small plastic detents holding the screen in place.
    • Disconnect the display cable and remove the screen.
  3. HP Pavilion 14-n018us Display Assembly Replacement: step 3, image 1 of 1
    • The screen can now be reassembled!
Michael Hollister
253 Reputation
3 Guides authored
Casper College, Team 1-1, Lareau Fall 2021 Member of Casper College, Team 1-1, Lareau Fall 2021
CASC-LAREAU-F21S1G1
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 224
