HP Pavilion 15-AB153NR RAM Replacement
  1. HP Pavilion 15-AB153NR RAM Replacement, Battery: step 1, image 1 of 1
    • Ensure computer is turned off and unplugged.
    • Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
  2. HP Pavilion 15-AB153NR RAM Replacement: step 2, image 1 of 2 HP Pavilion 15-AB153NR RAM Replacement: step 2, image 2 of 2
    • Slide the battery release latch on the right with continuous force from right to left.
    • Once battery pops, you may release latch.
  3. HP Pavilion 15-AB153NR RAM Replacement: step 3, image 1 of 2 HP Pavilion 15-AB153NR RAM Replacement: step 3, image 2 of 2
    • Grab the battery, rotating upwards and away from you. This will remove the battery.
  4. HP Pavilion 15-AB153NR RAM Replacement, CD/DVD Drive: step 4, image 1 of 1
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  5. HP Pavilion 15-AB153NR RAM Replacement: step 5, image 1 of 1
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  6. HP Pavilion 15-AB153NR RAM Replacement: step 6, image 1 of 2 HP Pavilion 15-AB153NR RAM Replacement: step 6, image 2 of 2
    • Slide the drive out from the right side of the device.
  7. HP Pavilion 15-AB153NR RAM Replacement, Bottom Case Cover: step 7, image 1 of 1
    • Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
  8. HP Pavilion 15-AB153NR RAM Replacement: step 8, image 1 of 2 HP Pavilion 15-AB153NR RAM Replacement: step 8, image 2 of 2
    • Lift the corner covers off of the computer using a prying tool.
  9. HP Pavilion 15-AB153NR RAM Replacement: step 9, image 1 of 1
    • Remove the six 6.5mm screws using a Phillips #1 screwdriver that are located near the top of the laptop.
  10. HP Pavilion 15-AB153NR RAM Replacement: step 10, image 1 of 1
    • Remove the remaining seven 6.5mm screws using a Phillips #1 screwdriver that are securing the back cover.
  11. HP Pavilion 15-AB153NR RAM Replacement: step 11, image 1 of 1
    • Use the Phillips #0 screwdriver to remove the two 2mm screws.
  12. HP Pavilion 15-AB153NR RAM Replacement: step 12, image 1 of 3 HP Pavilion 15-AB153NR RAM Replacement: step 12, image 2 of 3 HP Pavilion 15-AB153NR RAM Replacement: step 12, image 3 of 3
    • Use prying tools to pry the covers off of the screwholes.
    • Using the Phillips #1 screwdriver, remove the two 6.5mm screws.
  13. HP Pavilion 15-AB153NR RAM Replacement: step 13, image 1 of 1
    • Be mindful of sharp edges on computer while using prying tools.
    • Flip computer over and open so that the screen is facing you.
    • Starting at the bottom right corner, insert the prying tool and lift upwards to loosen the back panel.
    • Continue down all sides and corners of the device.
  14. HP Pavilion 15-AB153NR RAM Replacement: step 14, image 1 of 2 HP Pavilion 15-AB153NR RAM Replacement: step 14, image 2 of 2
    • Flip laptop back over so that the bottom is facing up
    • After all sides are loosened, remove the back panel from the device.
  15. HP Pavilion 15-AB153NR RAM Replacement, RAM: step 15, image 1 of 1
    • Spread retaining tabs on each side of the RAM slot to release.
    • RAM should automatically tilt up.
  16. HP Pavilion 15-AB153NR RAM Replacement: step 16, image 1 of 2 HP Pavilion 15-AB153NR RAM Replacement: step 16, image 2 of 2
    • Remove the RAM by pulling it away from the slot at at angle.
2 other people completed this guide.
Nicole Vachon
944 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 22
All Time: 345
