HP Pavilion 15-ab165us RAM Replacement
  1. HP Pavilion 15-ab165us RAM Replacement, Battery and Back Cover: step 1, image 1 of 2 HP Pavilion 15-ab165us RAM Replacement, Battery and Back Cover: step 1, image 2 of 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us RAM Replacement: step 2, image 1 of 3 HP Pavilion 15-ab165us RAM Replacement: step 2, image 2 of 3 HP Pavilion 15-ab165us RAM Replacement: step 2, image 3 of 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us RAM Replacement: step 3, image 1 of 3 HP Pavilion 15-ab165us RAM Replacement: step 3, image 2 of 3 HP Pavilion 15-ab165us RAM Replacement: step 3, image 3 of 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us RAM Replacement: step 4, image 1 of 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us RAM Replacement: step 5, image 1 of 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us RAM Replacement: step 6, image 1 of 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us RAM Replacement: step 7, image 1 of 2 HP Pavilion 15-ab165us RAM Replacement: step 7, image 2 of 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us RAM Replacement: step 8, image 1 of 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us RAM Replacement, RAM: step 9, image 1 of 1
    • Locate RAM.
  10. HP Pavilion 15-ab165us RAM Replacement: step 10, image 1 of 1
    • Pull the tension arms away from both sides the RAM.
  11. HP Pavilion 15-ab165us RAM Replacement: step 11, image 1 of 1
    • Pull RAM away from the RAM slot.
  12. HP Pavilion 15-ab165us RAM Replacement: step 12, image 1 of 1
    • Repeat this process for the next stick of RAM.
3 other people completed this guide.
Myai Nguyen
203 Reputation
1 Guide authored
UW Tacoma, Team S1-G2, Rose Fall 2017 Member of UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
5 Members
14 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 25
All Time: 2,384
