HP Pavilion 15-au123cl Battery Replacement
Video Overview
  1. HP Pavilion 15-au123cl Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Battery Replacement: step 2, image 1 of 2 HP Pavilion 15-au123cl Battery Replacement: step 2, image 2 of 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Battery Replacement: step 3, image 1 of 2 HP Pavilion 15-au123cl Battery Replacement: step 3, image 2 of 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Battery Replacement: step 4, image 1 of 2 HP Pavilion 15-au123cl Battery Replacement: step 4, image 2 of 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Battery Replacement: step 5, image 1 of 3 HP Pavilion 15-au123cl Battery Replacement: step 5, image 2 of 3 HP Pavilion 15-au123cl Battery Replacement: step 5, image 3 of 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
18 other people completed this guide.
Mohammad Gardezi
1,420 Reputation
6 Guides authored
USF Tampa, Team S13-G3, Cagle Fall 2017 Member of USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Members
6 Guides authored
6 Comments
That one screw under the rubber pad is a special kind of BS.
Liam Kosloski - Reply
The screw in the middle of everything was hardest for me to reinstall because it has to hold the CD drive in place ,and that drive hole must line up with everything else _just right_. Also, prying the keyboard from the shell was harder than I expected. It’s snapped in there pretty tight.
kctipton - Reply
The procedure should be modified to start with removing the center screw that retains the DVD drive and then pulling out the drive. That makes separating the case halves easier.
George Mells - Reply
My problem on ebay and amazon i only got aftermarket battery they claim oem 849909-850
I BOUGHT 3 SO FAR SAME THING …HP SAYS THEY DONT HAVE THE BATTERY FOR SALE ANY LONGER
Laptop wont start with nee battery … i conect old one with power on , once start conect new one and works
When shutdown or sleep it wont start with new battery
Will restart with new battery and last up to 6 hours new battery but wont start.
How can i start my laptop with new battery ?
Juan Carlos Gomez - Reply
It would be useful to have a heads up on how to get the CD/DVD drive back in place. I found ejecting the CD tray before shutdown and disassembly gave me some wiggle room when reinstalling. Then, you have to slide the CD plug into the motherboard jack before snapping the back cover into place. Make sure the screw hole on the CD drive aligns properly with the screw hole on the motherboard.
Also, my battery had 3 screws; one at the "top," one at each bottom corner.
John Darago - Reply
Past 24 Hours: 9
Past 7 Days: 16
Past 30 Days: 57
All Time: 24,397
