Introduction
This guide provides instructions for replacing the RAM of your HP Pavilion15-ay041wm.
RAM makes your laptop's performance work fast. This can be seen in everyday tasks, such as loading applications or browsing the internet.
This guide may be necessary if your laptop is slow in performance.
Before replacing the RAM, restart the laptop, as that may fix the issue. If it does not, be sure to power down the device and check and disconnect any cables from the computer, beginning with this guide.
Turn the laptop upside down with the base of the laptop facing you.
Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
Using the Jimmy, create a separation between the keyboard and bottom panel.
Slide around the body of the panel until the separation is big enough for you to use your fingers.
Separate the keyboard and bottom panel.
Orient the base of the laptop with the base facing away from you.
With you index finger and thumb, position your thumb underneath both latches on either side of the RAM and squeeze outwards.
Simultaneously, use your index finger to push the RAM sticks towards you.
The RAM stick will release and pop up and out.
