HP Pavilion 15-ba003ds Charging Port Replacement
  1. HP Pavilion 15-ba003ds Charging Port Replacement, Battery: step 1, image 1 of 2 HP Pavilion 15-ba003ds Charging Port Replacement, Battery: step 1, image 2 of 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: step 2, image 1 of 3 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: step 2, image 2 of 3 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: step 2, image 3 of 3
    • Use a Jimmy to pry off the black backplate.
  3. HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: step 3, image 1 of 2 HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: step 3, image 2 of 2
    • Remove three black 6mm Phillips #00 screws.
  4. HP Pavilion 15-ba003ds Charging Port Replacement: step 4, image 1 of 3 HP Pavilion 15-ba003ds Charging Port Replacement: step 4, image 2 of 3 HP Pavilion 15-ba003ds Charging Port Replacement: step 4, image 3 of 3
    • Unplug the white connector using your fingers or a spudger.
  5. HP Pavilion 15-ba003ds Charging Port Replacement: step 5, image 1 of 3 HP Pavilion 15-ba003ds Charging Port Replacement: step 5, image 2 of 3 HP Pavilion 15-ba003ds Charging Port Replacement: step 5, image 3 of 3
    • Pull out the fan by hand.
  6. HP Pavilion 15-ba003ds Charging Port Replacement, Charging Port: step 6, image 1 of 1
    • Use a spudger to disconnect the power cable from the motherboard.
  7. HP Pavilion 15-ba003ds Charging Port Replacement: step 7, image 1 of 3 HP Pavilion 15-ba003ds Charging Port Replacement: step 7, image 2 of 3 HP Pavilion 15-ba003ds Charging Port Replacement: step 7, image 3 of 3
    • Remove two 8mm Phillips #2 screws from the metal plate.
    • Use your hand to flip the metal plate so you can see the charging port fully.
  8. HP Pavilion 15-ba003ds Charging Port Replacement: step 8, image 1 of 2 HP Pavilion 15-ba003ds Charging Port Replacement: step 8, image 2 of 2
    • Use a spudger to pry off the charging port.
LI XU
334 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 31
All Time: 2,210
