HP Pavilion 15-ba003ds Cooling Fan Replacement
  1. HP Pavilion 15-ba003ds Cooling Fan Replacement, Battery: step 1, image 1 of 2 HP Pavilion 15-ba003ds Cooling Fan Replacement, Battery: step 1, image 2 of 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Cooling Fan Replacement, Disc Drive: step 2, image 1 of 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Cooling Fan Replacement: step 3, image 1 of 2 HP Pavilion 15-ba003ds Cooling Fan Replacement: step 3, image 2 of 2
    • Remove twelve 8mm Phillips #00 screws including two underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Cooling Fan Replacement: step 4, image 1 of 2 HP Pavilion 15-ba003ds Cooling Fan Replacement: step 4, image 2 of 2
    • Pull out the disc drive by hand.
  5. HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: step 5, image 1 of 3 HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: step 5, image 2 of 3 HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: step 5, image 3 of 3
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds Cooling Fan Replacement, Cooling Fan: step 6, image 1 of 2 HP Pavilion 15-ba003ds Cooling Fan Replacement, Cooling Fan: step 6, image 2 of 2
    • Remove three black 6mm Phillips #00 screws.
  7. HP Pavilion 15-ba003ds Cooling Fan Replacement: step 7, image 1 of 3 HP Pavilion 15-ba003ds Cooling Fan Replacement: step 7, image 2 of 3 HP Pavilion 15-ba003ds Cooling Fan Replacement: step 7, image 3 of 3
    • Unplug the white connector using your fingers or a spudger.
  8. HP Pavilion 15-ba003ds Cooling Fan Replacement: step 8, image 1 of 3 HP Pavilion 15-ba003ds Cooling Fan Replacement: step 8, image 2 of 3 HP Pavilion 15-ba003ds Cooling Fan Replacement: step 8, image 3 of 3
    • Pull out the fan by hand.
Krushnam Badami
342 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 296
