HP Pavilion 15-ca2073cl Display-Pad Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. HP Pavilion 15-ca2073cl Display-Pad Replacement, Back Cover: step 1, image 1 of 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl Display-Pad Replacement: step 2, image 1 of 2 HP Pavilion 15-ca2073cl Display-Pad Replacement: step 2, image 2 of 2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl Display-Pad Replacement, Battery: step 3, image 1 of 2 HP Pavilion 15-ca2073cl Display-Pad Replacement, Battery: step 3, image 2 of 2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl Display-Pad Replacement, Display-Pad: step 4, image 1 of 1
    • Open the laptop like you normally would if you were about to use it and use a plastic spudger to separate the top cover from the bottom.
    • While lifting the top cover, undo the clip holding the keyboard cable in place and pull the cable out.
  5. HP Pavilion 15-ca2073cl Display-Pad Replacement: step 5, image 1 of 2 HP Pavilion 15-ca2073cl Display-Pad Replacement: step 5, image 2 of 2
    • Remove the screws from the display to the frame of the laptop.
    • Remove the cables that connect to the motherboard.
  6. HP Pavilion 15-ca2073cl Display-Pad Replacement: step 6, image 1 of 1
    • Gently remove the display from the rest of the laptop.
  7. HP Pavilion 15-ca2073cl Display-Pad Replacement: step 7, image 1 of 1
    • Using a spudger, remove the cover from the display pad.
  8. HP Pavilion 15-ca2073cl Display-Pad Replacement: step 8, image 1 of 2 HP Pavilion 15-ca2073cl Display-Pad Replacement: step 8, image 2 of 2
    • Remove the screws surrounding the display.
    • Using the spudger, pry the display from the display pad.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 37
