HP Pavilion 15-ca2073cl Motherboard Replacement
  1. HP Pavilion 15-ca2073cl Motherboard  Replacement, Back Cover: step 1, image 1 of 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl Motherboard  Replacement: step 2, image 1 of 2 HP Pavilion 15-ca2073cl Motherboard  Replacement: step 2, image 2 of 2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl Motherboard  Replacement, Battery: step 3, image 1 of 2 HP Pavilion 15-ca2073cl Motherboard  Replacement, Battery: step 3, image 2 of 2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl Motherboard  Replacement, Motherboard: step 4, image 1 of 2 HP Pavilion 15-ca2073cl Motherboard  Replacement, Motherboard: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the screws surrounding the motherboard using the Phillips #00 screwdriver.
    • Dismount the power supply ribbon cable by lifting the cable lock and pulling the cable with the flat-tipped tweezers.
    • Gently remove and disconnect the two display ribbon cables located at the top right corner of the moother board.
    • Disconnect the keyboard cable next to the power supply cable.
    • Disconnect the disc and hard drive cables.
  5. HP Pavilion 15-ca2073cl Motherboard  Replacement: step 5, image 1 of 1
    • Using the flat-tipped tweezers, remove the cable wrapping around the left fan connecting to the mother board.
  6. HP Pavilion 15-ca2073cl Motherboard  Replacement: step 6, image 1 of 1
    • Remove the three Phillips #00 screws surrounding the fans.
    • Remove the cables connecting the fans to the motherboard.
    • Gently lift the fans out of place.
  7. HP Pavilion 15-ca2073cl Motherboard  Replacement: step 7, image 1 of 2 HP Pavilion 15-ca2073cl Motherboard  Replacement: step 7, image 2 of 2
    • Using the spudger, begin to pry all ports connected to the motherboard away from the shell of the laptop.
    • Using the spudger, gently pry the motherboard up and out.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 964
