HP Pavilion 15-eg0025nr Back Panel Replacement
  1. HP Pavilion 15-eg0025nr Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Unplug and turn off the laptop before removing the back panel
    • Flip over the computer so that the back panel is facing upwards.
    • Remove the two silver screws on the bottom of the laptop using a Phillips #00 screwdriver.
  2. HP Pavilion 15-eg0025nr Back Panel Replacement: step 2, image 1 of 2 HP Pavilion 15-eg0025nr Back Panel Replacement: step 2, image 2 of 2
    • Peel up each end of the two gray rubber stoppers using your fingers or an opening pick.
    • This may be difficult if it is your first time removing them.
    • Remove the two black screws underneath the rubber stoppers with the Phillips #00 screwdriver
  3. HP Pavilion 15-eg0025nr Back Panel Replacement: step 3, image 1 of 3 HP Pavilion 15-eg0025nr Back Panel Replacement: step 3, image 2 of 3 HP Pavilion 15-eg0025nr Back Panel Replacement: step 3, image 3 of 3
    • Slide the opening pick around the edges of the laptop where the chassis has a seam.
    • You will hear a clicking noise as you undo the clips of the chassis.
    • It may be easier to start with the four corners of the laptop, and then follow through with the sides.
  4. HP Pavilion 15-eg0025nr Back Panel Replacement: step 4, image 1 of 1
    • Remove the back panel completely.
    • With the back panel removed, you can now access parts of the laptop such as the fan or the battery.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 74
All Time: 976
