HP Pavilion 15-n232nr Hard Drive Replacement
  1. HP Pavilion 15-n232nr Hard Drive Replacement, Battery: step 1, image 1 of 2 HP Pavilion 15-n232nr Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop over.
  2. HP Pavilion 15-n232nr Hard Drive Replacement: step 2, image 1 of 3 HP Pavilion 15-n232nr Hard Drive Replacement: step 2, image 2 of 3 HP Pavilion 15-n232nr Hard Drive Replacement: step 2, image 3 of 3
    • Slide the battery locks towards the center of the laptop. The battery will detach automatically.
    • Remove the battery by sliding it away from the laptop housing.
  3. HP Pavilion 15-n232nr Hard Drive Replacement, Keyboard: step 3, image 1 of 2 HP Pavilion 15-n232nr Hard Drive Replacement, Keyboard: step 3, image 2 of 2
    • Unscrew the 6 mm Phillips #1 screw securing the keyboard.
  4. HP Pavilion 15-n232nr Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion 15-n232nr Hard Drive Replacement: step 4, image 2 of 2
    • Flip the laptop to the front side and open it up.
  5. HP Pavilion 15-n232nr Hard Drive Replacement: step 5, image 1 of 2 HP Pavilion 15-n232nr Hard Drive Replacement: step 5, image 2 of 2
    • Use the metal spudger to release the keyboard from the front panel.
  6. HP Pavilion 15-n232nr Hard Drive Replacement: step 6, image 1 of 3 HP Pavilion 15-n232nr Hard Drive Replacement: step 6, image 2 of 3 HP Pavilion 15-n232nr Hard Drive Replacement: step 6, image 3 of 3
    • Flip the keyboard out and locate the connector.
    • Use the spudger to unhinge the the fastener and remove the connector.
    • Keyboard should be completely detached after this step.
  7. HP Pavilion 15-n232nr Hard Drive Replacement, Optical Drive: step 7, image 1 of 2 HP Pavilion 15-n232nr Hard Drive Replacement, Optical Drive: step 7, image 2 of 2
    • Remove the 6 mm Phillips #1 screw securing the optical drive.
  8. HP Pavilion 15-n232nr Hard Drive Replacement: step 8, image 1 of 2 HP Pavilion 15-n232nr Hard Drive Replacement: step 8, image 2 of 2
    • Use the iFixit opening tool to slide the optical drive away from the laptop housing.
  9. HP Pavilion 15-n232nr Hard Drive Replacement, Hard Drive: step 9, image 1 of 2 HP Pavilion 15-n232nr Hard Drive Replacement, Hard Drive: step 9, image 2 of 2
    • The battery and optical drive should be removed at this point in the process.
    • Remove the ten 6 mm Phillips #1 screws.
    • Remove the three 1 mm Phillips #000 screws.
  10. HP Pavilion 15-n232nr Hard Drive Replacement: step 10, image 1 of 2 HP Pavilion 15-n232nr Hard Drive Replacement: step 10, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the five 2.5mm Phillips #1 screws.
    • Use the spudger to unhinge the cable connectors. Use tweezers to complete removal.
  11. HP Pavilion 15-n232nr Hard Drive Replacement: step 11, image 1 of 3 HP Pavilion 15-n232nr Hard Drive Replacement: step 11, image 2 of 3 HP Pavilion 15-n232nr Hard Drive Replacement: step 11, image 3 of 3
    • Carefully use the iFixit opening tool to release the front panel.
  12. HP Pavilion 15-n232nr Hard Drive Replacement: step 12, image 1 of 3 HP Pavilion 15-n232nr Hard Drive Replacement: step 12, image 2 of 3 HP Pavilion 15-n232nr Hard Drive Replacement: step 12, image 3 of 3
    • Use the spudger to unhinge the daughterboard connector.
    • Remove daughterboard connector.
  13. HP Pavilion 15-n232nr Hard Drive Replacement: step 13, image 1 of 1
    • Remove the 2.5 mm Phillips #1 screw and remove the daughterboard
  14. HP Pavilion 15-n232nr Hard Drive Replacement: step 14, image 1 of 3 HP Pavilion 15-n232nr Hard Drive Replacement: step 14, image 2 of 3 HP Pavilion 15-n232nr Hard Drive Replacement: step 14, image 3 of 3
    • Use the iFixit opening tool to remove the hard drive connector.
    • Remove the hard drive by lifting the right side and pulling it out.
6 other people completed this guide.
2 Comments
How to test it's processor
Kashmir Singh - Reply
Great guide, thank you!!
alt255d - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,396
