HP Pavilion 15-p046nr Disk Drive Replacement
  1. HP Pavilion 15-p046nr Disk Drive Replacement, Battery: step 1, image 1 of 3 HP Pavilion 15-p046nr Disk Drive Replacement, Battery: step 1, image 2 of 3 HP Pavilion 15-p046nr Disk Drive Replacement, Battery: step 1, image 3 of 3
    • Flip the laptop over so the bottom is facing up.
    • Place your finger on the top left-hand slide button with the lock symbol.
    • Moving the slide does require some force.
    • Slide the button to the right so that an unlocked symbol is visible.
  2. HP Pavilion 15-p046nr Disk Drive Replacement: step 2, image 1 of 3 HP Pavilion 15-p046nr Disk Drive Replacement: step 2, image 2 of 3 HP Pavilion 15-p046nr Disk Drive Replacement: step 2, image 3 of 3
    • Place your finger or thumb on the top right-hand slide with the battery symbol visible.
    • Slide the button to the left.
    • Moving the slide will require some force.
    • Lift the battery off the computer with your thumb.
    • You will not need to slide the right button with the battery to reinstall the battery.
  3. HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: step 3, image 1 of 3 HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: step 3, image 2 of 3 HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: step 3, image 3 of 3
    • Remove one 7 mm, Phillips #00 screw from the back panel.
    • Open the disk drive by gently pulling on the drive.
    • Pull the disk drive out and away from the device.
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 11
All Time: 244
