Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
Remove this screw using a Philips #0 screwdriver.
Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's bottom face. These screws are all about 7.5mm long.
Undo the clip holding the small circuit cable.
Gently pull the cable out from the clip.
