HP Pavilion 17-ak008cy Fan Replacement
  1. HP Pavilion 17-ak008cy Fan Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over so that the underside is facing you.
  2. HP Pavilion 17-ak008cy Fan Replacement: step 2, image 1 of 3 HP Pavilion 17-ak008cy Fan Replacement: step 2, image 2 of 3 HP Pavilion 17-ak008cy Fan Replacement: step 2, image 3 of 3
    • Using your hands, push the two tabs inwards to release the battery.
    • Remove the battery from the device.
  3. HP Pavilion 17-ak008cy Fan Replacement, Back Panel: step 3, image 1 of 2 HP Pavilion 17-ak008cy Fan Replacement, Back Panel: step 3, image 2 of 2
    • Remove eleven screws from the back panel.
    • Remove the back panel from the device.
  4. HP Pavilion 17-ak008cy Fan Replacement, Fan: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the single screw securing the fan to the motherboard.
  5. HP Pavilion 17-ak008cy Fan Replacement: step 5, image 1 of 2 HP Pavilion 17-ak008cy Fan Replacement: step 5, image 2 of 2
    • Disconnect the fan wire carefully so that the fan is longer connected to the motherboard.
  6. HP Pavilion 17-ak008cy Fan Replacement: step 6, image 1 of 2 HP Pavilion 17-ak008cy Fan Replacement: step 6, image 2 of 2
    • Remove the fan from the device.
Mohammad Alchaar
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 207
