HP Pavilion 17-ak008cy Speakers Replacement
Andrew Boardman
Andrew Boardman and 2 other contributors
Last updated on January 3, 2022
8 - 15 minutes
Easy
Action Shots
Needs Better Images
Needs More Images
Better Introduction
Introduction
Go to step 1
Overall there very little new cautions and hazards added to this guide. When looking at issues that may be caused by faulty or damaged speaker, is lack of sound or damaged wires. Accessing the speakers can only be accomplished after the prerequisites are met which are listed later on.
Tools
  1. HP Pavilion 17-ak008cy Speakers Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over so that the underside is facing you.
  2. HP Pavilion 17-ak008cy Speakers Replacement: step 2, image 1 of 3 HP Pavilion 17-ak008cy Speakers Replacement: step 2, image 2 of 3 HP Pavilion 17-ak008cy Speakers Replacement: step 2, image 3 of 3
    • Using your hands, push the two tabs inwards to release the battery.
    • Remove the battery from the device.
  3. HP Pavilion 17-ak008cy Speakers Replacement, Back Panel: step 3, image 1 of 3 HP Pavilion 17-ak008cy Speakers Replacement, Back Panel: step 3, image 2 of 3 HP Pavilion 17-ak008cy Speakers Replacement, Back Panel: step 3, image 3 of 3
    • Remove eleven screws from the back panel.
    • Remove the optical drive from the side.
    • Remove the back panel from the device.
  4. HP Pavilion 17-ak008cy Speakers Replacement, Speakers: step 4, image 1 of 3 HP Pavilion 17-ak008cy Speakers Replacement, Speakers: step 4, image 2 of 3 HP Pavilion 17-ak008cy Speakers Replacement, Speakers: step 4, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the two screws (one on each speaker) securing the speakers to the motherboard.
  5. HP Pavilion 17-ak008cy Speakers Replacement: step 5, image 1 of 2 HP Pavilion 17-ak008cy Speakers Replacement: step 5, image 2 of 2
    • Gently unplug the speaker connector from the motherboard.
  6. HP Pavilion 17-ak008cy Speakers Replacement: step 6, image 1 of 2 HP Pavilion 17-ak008cy Speakers Replacement: step 6, image 2 of 2
    • Carefully untangle the red wires tucked in between the black plastic tabs.
    • Remove the speakers from the device.
3 other people completed this guide.
Andrew Boardman
487 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 121
