HP Pavilion 17-e117dx Hard Drive Replacement
  1. HP Pavilion 17-e117dx Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx Hard Drive Replacement: step 2, image 1 of 2 HP Pavilion 17-e117dx Hard Drive Replacement: step 2, image 2 of 2
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx Hard Drive Replacement, Service Panel: step 3, image 1 of 2 HP Pavilion 17-e117dx Hard Drive Replacement, Service Panel: step 3, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx Hard Drive Replacement: step 4, image 1 of 1
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx Hard Drive Replacement: step 5, image 1 of 1
    • Remove the service panel.
  6. HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: step 6, image 1 of 3 HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: step 6, image 2 of 3 HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: step 6, image 3 of 3
    • Remove the two Phillips 2.5 x 5.75 mm screws that hold the hard drive down to the computer.
    • Use the Phillips #00 screwdriver.
  7. HP Pavilion 17-e117dx Hard Drive Replacement: step 7, image 1 of 3 HP Pavilion 17-e117dx Hard Drive Replacement: step 7, image 2 of 3 HP Pavilion 17-e117dx Hard Drive Replacement: step 7, image 3 of 3
    • Disconnect the hard drive connector cable from the computer's system board.
  8. HP Pavilion 17-e117dx Hard Drive Replacement: step 8, image 1 of 2 HP Pavilion 17-e117dx Hard Drive Replacement: step 8, image 2 of 2
    • Lift the hard drive out of the hard drive bay by lifting up from the tab.
    • Remove the hard drive from the computer.
2 other people completed this guide.
Marcel Amazan
576 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 33
All Time: 1,912
