HP Pavilion 17-e117dx Optical Drive Replacement
  1. HP Pavilion 17-e117dx Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx Optical Drive Replacement: step 2, image 1 of 2 HP Pavilion 17-e117dx Optical Drive Replacement: step 2, image 2 of 2
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx Optical Drive Replacement, Service Panel: step 3, image 1 of 2 HP Pavilion 17-e117dx Optical Drive Replacement, Service Panel: step 3, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx Optical Drive Replacement: step 4, image 1 of 1
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx Optical Drive Replacement: step 5, image 1 of 1
    • Remove the service panel.
  6. HP Pavilion 17-e117dx Optical Drive Replacement, Optical Drive: step 6, image 1 of 2 HP Pavilion 17-e117dx Optical Drive Replacement, Optical Drive: step 6, image 2 of 2
    • Remove the single Phillips PM 2.5 x 5.75 screw that secures the optical drive to the computer.
    • Use the Phillips #00 screwdriver.
  7. HP Pavilion 17-e117dx Optical Drive Replacement: step 7, image 1 of 3 HP Pavilion 17-e117dx Optical Drive Replacement: step 7, image 2 of 3 HP Pavilion 17-e117dx Optical Drive Replacement: step 7, image 3 of 3
    • Slide the optical drive out of the computer.
Marcel Amazan
576 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 408
