HP Pavilion 17-e117dx WLAN Module Replacement
  1. HP Pavilion 17-e117dx WLAN Module Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx WLAN Module Replacement: step 2, image 1 of 2 HP Pavilion 17-e117dx WLAN Module Replacement: step 2, image 2 of 2
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx WLAN Module Replacement, Service Panel: step 3, image 1 of 2 HP Pavilion 17-e117dx WLAN Module Replacement, Service Panel: step 3, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx WLAN Module Replacement: step 4, image 1 of 1
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx WLAN Module Replacement: step 5, image 1 of 1
    • Remove the service panel.
  6. HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: step 6, image 1 of 3 HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: step 6, image 2 of 3 HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: step 6, image 3 of 3
    • Remove the two antenna cables from the top of the WLAN module by pulling them upwards.
    • Be gentle when removing the cables. You don't want to damage them.
  7. HP Pavilion 17-e117dx WLAN Module Replacement: step 7, image 1 of 2 HP Pavilion 17-e117dx WLAN Module Replacement: step 7, image 2 of 2
    • Remove the single Phillips PM 2.5 x 3.25 screw so that you can remove the WLAN module from the system board.
    • Use the Phillips #00 screwdriver.
  8. HP Pavilion 17-e117dx WLAN Module Replacement: step 8, image 1 of 1
    • To remove the WLAN module, pull it away from the slot at an angle.
Marcel Amazan
576 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 551
