HP Pavilion 17-f127ds Optical Drive Replacement
  1. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: step 1, image 1 of 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: step 1, image 2 of 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: step 1, image 3 of 3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: step 2, image 1 of 2 HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the screw holding the Optical Drive in place. It is located near the center and vents of the laptop.
    • Use a spudger to help unseat the drive. Pull the drive out from the laptop.
  3. HP Pavilion 17-f127ds Optical Drive Replacement: step 3, image 1 of 1
    • If you need to replace the bracket on the Optical drive, remove the two Phillips #0 screws holding the bracket in place. The bracket can be placed on the new drive.
Stephen Brown
201 Reputation
2 Guides authored
UW Tacoma, Team S3-G1, Liner Fall 2017 Member of UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
5 Members
4 Guides authored
One Comment
I can’t remove the HP Pavilion 17-x016ds Optical Drive. NEED HELP. Is it necessary to remove it in order to remove bottom panel to replace HDD with SSD? Also can’t remove bottom panel.
Nick Koriakin - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 934
