HP Pavilion 17-x047na Fan Replacement
  1. HP Pavilion 17-x047na Fan Replacement, Battery: step 1, image 1 of 2 HP Pavilion 17-x047na Fan Replacement, Battery: step 1, image 2 of 2
    • Turn off and unplug the laptop before replacing the battery.
    • The netbook needs to be top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
  2. HP Pavilion 17-x047na Fan Replacement: step 2, image 1 of 1
    • Slide the battery out from the laptop.
  3. HP Pavilion 17-x047na Fan Replacement, Back Panel: step 3, image 1 of 2 HP Pavilion 17-x047na Fan Replacement, Back Panel: step 3, image 2 of 2
    • Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
    • Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
    • Use an ejection pin to eject and remove the CD/DVD drive.
  4. HP Pavilion 17-x047na Fan Replacement: step 4, image 1 of 2 HP Pavilion 17-x047na Fan Replacement: step 4, image 2 of 2
    • Use an iFixit opening tool to separate the back cover from the laptop.
    • Gently pry open the cover, trying not to break the plastic.
  5. HP Pavilion 17-x047na Fan Replacement, Fan: step 5, image 1 of 1
    • Remove the five screws attaching the fan to the motherboard using a Phillips #0.
    • Disconnect the wire connecting the fan to the motherboard.
  6. HP Pavilion 17-x047na Fan Replacement: step 6, image 1 of 3 HP Pavilion 17-x047na Fan Replacement: step 6, image 2 of 3 HP Pavilion 17-x047na Fan Replacement: step 6, image 3 of 3
    • Using a Phillips # 0 screwdriver, remove the five 3.0 mm screws.
    • Disconnect the wire.
    • Then remove the fan.
Khaise Brice
459 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 208
