HP Pavilion DM3-3010US Hard Drive Replacement
  1. HP Pavilion DM3-3010US Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Flip laptop over to back with the battery facing downwards.
    • The battery is the silver cylinder located on the bottom of the laptop.
  2. HP Pavilion DM3-3010US Hard Drive Replacement: step 2, image 1 of 1
    • Locate switch for battery ejection.
    • Battery ejection switch is located just above the left side of the battery.
  3. HP Pavilion DM3-3010US Hard Drive Replacement: step 3, image 1 of 1
    • Remove battery by sliding the battery ejection switch to the right and pulling the battery away from the laptop.
  4. HP Pavilion DM3-3010US Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion DM3-3010US Hard Drive Replacement: step 4, image 2 of 2
    • Using a plastic opening tool, remove the large square casing located on the bottom right side of the laptop.
    • The hard drive will be visible once the casing has been removed.
  5. HP Pavilion DM3-3010US Hard Drive Replacement: step 5, image 1 of 2 HP Pavilion DM3-3010US Hard Drive Replacement: step 5, image 2 of 2
    • Using a Phillips #0 Screwdriver, remove each of the six Phillips #0 screws.
    • Four screws are located on each corner of the hard-drive.
    • Two screws are located on the right side of the battery slot.
  6. HP Pavilion DM3-3010US Hard Drive Replacement: step 6, image 1 of 1
    • Remove old hard drive from its slot and replace with new hard drive, sticker side facing up.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 1,863
