HP Pavilion DV2160BR Hard Drive Replacement
  1. HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Start with the bottom of the laptop facing up.
    • Locate the panel covering the hard drive compartment.
    • Unscrew the two 5mm Phillips #0 screws.
  2. HP Pavilion DV2160BR Hard Drive Replacement: step 2, image 1 of 1
    • Lift up this external panel by the end with the screws and set it aside.
    • Be careful about the four plastic tabs holding the panel on the device.
  3. HP Pavilion DV2160BR Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion DV2160BR Hard Drive Replacement: step 3, image 2 of 2
    • Locate the second plastic panel covering the hard drive.
    • Unscrew the two 4mm Phillips #0 screws holding it in.
  4. HP Pavilion DV2160BR Hard Drive Replacement: step 4, image 1 of 1
    • Lift up this internal panel using the plastic white tab and set it aside.
  5. HP Pavilion DV2160BR Hard Drive Replacement: step 5, image 1 of 3 HP Pavilion DV2160BR Hard Drive Replacement: step 5, image 2 of 3 HP Pavilion DV2160BR Hard Drive Replacement: step 5, image 3 of 3
    • Grab the end of the hard drive and pull it up to a vertical position.
    • Gently slide the Hard Drive off of the SATA connector.
    • Warning: Don’t wiggle the SATA connector or the top piece will come off. If it does, reconnect it vertically.
Shannon
55 Reputation
6 Guides authored
Cal Poly, Team 13-66, Johann Spring 2013 Member of Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 535
