HP Pavilion DV2160BR RAM Replacement
  1. HP Pavilion DV2160BR RAM Replacement, RAM: step 1, image 1 of 2 HP Pavilion DV2160BR RAM Replacement, RAM: step 1, image 2 of 2
    • Start with the bottom of the laptop facing up.
    • Locate the panel that is covering the RAM compartment.
    • Unscrew the two 5mm Phillips #0 screws that are securing the RAM compartment.
  2. HP Pavilion DV2160BR RAM Replacement: step 2, image 1 of 2 HP Pavilion DV2160BR RAM Replacement: step 2, image 2 of 2
    • Lift up the panel that is by the end that held the screws. Set it aside.
  3. HP Pavilion DV2160BR RAM Replacement: step 3, image 1 of 3 HP Pavilion DV2160BR RAM Replacement: step 3, image 2 of 3 HP Pavilion DV2160BR RAM Replacement: step 3, image 3 of 3
    • Using 2 prying tools, push the 2 buttons on the sides of one RAM module simultaneously, so that one side of the module pops up and out of the clips holding it down.
    • Grab the RAM module and carefully pull it straight out of its slot.
    • Repeat this step for the second RAM module, which is located just underneath the first RAM module.
Shannon
55 Reputation
6 Guides authored
Cal Poly, Team 13-66, Johann Spring 2013 Member of Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 380
