HP Pavilion DV2160BR Wifi Adapter Replacement
  1. HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: step 1, image 1 of 2 HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: step 1, image 2 of 2
    • Start with the bottom of the laptop facing up.
    • Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
    • Remove the panel and set it aside.
    • Be careful not to snap the 2 tabs on the sides of the panel when pulling it out.
  2. HP Pavilion DV2160BR Wifi Adapter Replacement: step 2, image 1 of 2 HP Pavilion DV2160BR Wifi Adapter Replacement: step 2, image 2 of 2
    • Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
  3. HP Pavilion DV2160BR Wifi Adapter Replacement: step 3, image 1 of 2 HP Pavilion DV2160BR Wifi Adapter Replacement: step 3, image 2 of 2
    • Pull the 2 black wires with the gold pieces out of the wifi adapter.
    • The wifi adapter is now free to be removed.
    • When reconnecting the wires for re-installing the wifi adapter, make sure the gold ends are rotated correctly to be properly pushed back in.
Shannon
55 Reputation
6 Guides authored
Cal Poly, Team 13-66, Johann Spring 2013 Member of Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 533
