HP Pavilion DV3 Battery Replacement
Luke Whitmarsh
Luke Whitmarsh and 5 other contributors
Last updated on January 28, 2014
2 minutes
Very easy
Needs Better Images
Introduction
Go to step 1
You will be removing the battery. This is a short and simple guide.
  1. HP Pavilion DV3 Battery Replacement, Battery: step 1, image 1 of 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 Battery Replacement: step 2, image 1 of 2 HP Pavilion DV3 Battery Replacement: step 2, image 2 of 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
2 other people completed this guide.
Luke Whitmarsh
649 Reputation
2 Guides authored
Cal Poly, Team 14-10, Forte Fall 2013 Member of Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,702
