HP Pavilion DV3 Hard Drive Replacement
  1. HP Pavilion DV3 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 Hard Drive Replacement: step 2, image 1 of 2 HP Pavilion DV3 Hard Drive Replacement: step 2, image 2 of 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Locate the screw for the hard drive cover (The cover has HP ProtectSmart written on it).
    • Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
    • The screw will remain attached to the cover.
  4. HP Pavilion DV3 Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion DV3 Hard Drive Replacement: step 4, image 2 of 2
    • Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
    • Put the cover and screw to the.
    • This will reveal the hard drive.
  5. HP Pavilion DV3 Hard Drive Replacement: step 5, image 1 of 3 HP Pavilion DV3 Hard Drive Replacement: step 5, image 2 of 3 HP Pavilion DV3 Hard Drive Replacement: step 5, image 3 of 3
    • With your fingers, grab the clear tab.
    • Pull right first, and then upwards (towards you).
    • The hard drive should slide out of place and detach from the laptop.
5 other people completed this guide.
Luke Whitmarsh
649 Reputation
2 Guides authored
Cal Poly, Team 14-10, Forte Fall 2013 Member of Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 4,985
