HP Pavilion DV3 RAM Replacement
  1. HP Pavilion DV3 RAM Replacement, Battery: step 1, image 1 of 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 RAM Replacement: step 2, image 1 of 2 HP Pavilion DV3 RAM Replacement: step 2, image 2 of 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 RAM Replacement, RAM: step 3, image 1 of 3 HP Pavilion DV3 RAM Replacement, RAM: step 3, image 2 of 3 HP Pavilion DV3 RAM Replacement, RAM: step 3, image 3 of 3
    • Remove the two 3.5 mm diameter head and 7 mm long screws using the Philips PH1 screwdriver.
    • Both screws will remain attached to the cover.
    • Set the cover with attached screws to the side.
    • The RAM will now be exposed
  4. HP Pavilion DV3 RAM Replacement: step 4, image 1 of 3 HP Pavilion DV3 RAM Replacement: step 4, image 2 of 3 HP Pavilion DV3 RAM Replacement: step 4, image 3 of 3
    • Find the two clips located on each side of the RAM.
    • Using both hands, simultaneously grab each clip and open them away from the RAM stick.
    • The RAM will pop up.
  5. HP Pavilion DV3 RAM Replacement: step 5, image 1 of 2 HP Pavilion DV3 RAM Replacement: step 5, image 2 of 2
    • Using one hand, pull the RAM up and to the left to remove it.
  6. HP Pavilion DV3 RAM Replacement: step 6, image 1 of 1
    • If there is a second RAM module present (as shown), repeat steps 2 and 3 to remove it.
2 other people completed this guide.
Brandon Baldovin
548 Reputation
3 Guides authored
Cal Poly, Team 14-10, Forte Fall 2013 Member of Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 2,152
