HP Pavilion G6 Screen Replacement
  1. HP Pavilion G6  Screen Replacement, Remove the battery: step 1, image 1 of 3 HP Pavilion G6  Screen Replacement, Remove the battery: step 1, image 2 of 3 HP Pavilion G6  Screen Replacement, Remove the battery: step 1, image 3 of 3
    • Close the laptop and flip it over.
    • Slide the release pin to pop the battery.
    • Remove the battery completely.
  2. HP Pavilion G6  Screen Replacement, Remove the screw covers: step 2, image 1 of 3 HP Pavilion G6  Screen Replacement, Remove the screw covers: step 2, image 2 of 3 HP Pavilion G6  Screen Replacement, Remove the screw covers: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Open the laptop and locate the screw covers.
    • Remove the screw covers at the bottom of the screen with tweezers.
    • Keep them somewhere safe as you will need to stick them back after the repair.
  3. HP Pavilion G6  Screen Replacement, Remove the plastic frame: step 3, image 1 of 3 HP Pavilion G6  Screen Replacement, Remove the plastic frame: step 3, image 2 of 3 HP Pavilion G6  Screen Replacement, Remove the plastic frame: step 3, image 3 of 3
    • Unscrew the exposed 2 x Philips screws and set them aside.
    • Starting from the top, pry up the plastic frame with your fingernails or a pry bar.
    • If you are using a pry bar, it can scratch the screen. Apply gentle pressure until the plastic frame pop out all around the frame. Don't force it!
    • Finally, remove the frame.
  4. HP Pavilion G6  Screen Replacement, Release the screen from the frame: step 4, image 1 of 3 HP Pavilion G6  Screen Replacement, Release the screen from the frame: step 4, image 2 of 3 HP Pavilion G6  Screen Replacement, Release the screen from the frame: step 4, image 3 of 3
    • Remove the black Philips screw from the top on each side.
    • Remove the bottom screw from the hinge to make an easier access to the screws on the side of the screen.
    • Now that the frame is loose, you can remove the 4 x Philips screws holding the screen in the frame.
  5. HP Pavilion G6  Screen Replacement, Disconnect the screen connector: step 5, image 1 of 3 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: step 5, image 2 of 3 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: step 5, image 3 of 3
    • Turn the laptop back up and carefully tilt the screen out from the frame and rest it on the keyboard.
    • Don't try to fully remove it yet as it is still attached to the motherboard by the screen cable!
    • Gently lift up the adhesive and disconnect the screen connector. That is the screen released and ready for a change for a new one.
  6. HP Pavilion G6  Screen Replacement, Check the model number before ordering: step 6, image 1 of 2 HP Pavilion G6  Screen Replacement, Check the model number before ordering: step 6, image 2 of 2
    • Before ordering a new screen make sure that you order the correct model number that is compatible with your old screen.
    • Check the cable connector to make sure you order the correct screen with the correct number of pins.
2 other people completed this guide.
honakrisi
3,946 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 1,799
