HP Pavilion G7-2289wm Hard Drive Replacement
  1. HP Pavilion G7-2289wm Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Hard Drive Replacement, Hard Drive: step 2, image 1 of 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Pull the edge of the service cover toward you to remove it.
  3. HP Pavilion G7-2289wm Hard Drive Replacement: step 3, image 1 of 1
    • Disconnect the hard drive connector cable from the motherboard.
  4. HP Pavilion G7-2289wm Hard Drive Replacement: step 4, image 1 of 1
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
Ryson Smith
636 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 209
