HP Pavilion G7-2289wm Touchpad Replacement
  1. HP Pavilion G7-2289wm Touchpad Replacement, Battery: step 1, image 1 of 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Touchpad Replacement, Hard Drive: step 2, image 1 of 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Pull the edge of the service cover toward you to remove it.
  3. HP Pavilion G7-2289wm Touchpad Replacement: step 3, image 1 of 1
    • Disconnect the hard drive connector cable from the motherboard.
  4. HP Pavilion G7-2289wm Touchpad Replacement: step 4, image 1 of 1
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
  5. HP Pavilion G7-2289wm Touchpad Replacement, Keyboard: step 5, image 1 of 1
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  6. HP Pavilion G7-2289wm Touchpad Replacement: step 6, image 1 of 3 HP Pavilion G7-2289wm Touchpad Replacement: step 6, image 2 of 3 HP Pavilion G7-2289wm Touchpad Replacement: step 6, image 3 of 3
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
  7. HP Pavilion G7-2289wm Touchpad Replacement, Touchpad: step 7, image 1 of 2 HP Pavilion G7-2289wm Touchpad Replacement, Touchpad: step 7, image 2 of 2
    • Remove the wires attached to the button pad.
  8. HP Pavilion G7-2289wm Touchpad Replacement: step 8, image 1 of 1
    • Carefully lift and remove the button board.
    • Remove all screws from the bottom of the laptop.
Ryson Smith
636 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 622
