HP Pavilion dm4-1265dx Clock Battery Replacement
  1. HP Pavilion dm4-1265dx Clock Battery Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Clock Battery Replacement: step 2, image 1 of 3 HP Pavilion dm4-1265dx Clock Battery Replacement: step 2, image 2 of 3 HP Pavilion dm4-1265dx Clock Battery Replacement: step 2, image 3 of 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: step 3, image 1 of 2 HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: step 3, image 2 of 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Clock Battery Replacement: step 4, image 1 of 3 HP Pavilion dm4-1265dx Clock Battery Replacement: step 4, image 2 of 3 HP Pavilion dm4-1265dx Clock Battery Replacement: step 4, image 3 of 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: step 5, image 1 of 3 HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: step 5, image 2 of 3 HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • The clock battery is a metallic disk near the battery port. The words "Lithium 3V" are on the face.
    • Disconnect the battery from the metallic fasteners using the tweezers.
    • Slightly bend the fasteners away from the battery.
    • Pick up the battery with the tweezers and dislodge from the fasteners.
  6. HP Pavilion dm4-1265dx Clock Battery Replacement: step 6, image 1 of 1
    • Fully remove battery from the laptop.
Isaiah Timbers
171 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 376
