HP Pavilion dm4-1265dx Hard Drive Replacement
  1. HP Pavilion dm4-1265dx Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Hard Drive Replacement: step 2, image 1 of 3 HP Pavilion dm4-1265dx Hard Drive Replacement: step 2, image 2 of 3 HP Pavilion dm4-1265dx Hard Drive Replacement: step 2, image 3 of 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: step 3, image 1 of 2 HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: step 3, image 2 of 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Hard Drive Replacement: step 4, image 1 of 3 HP Pavilion dm4-1265dx Hard Drive Replacement: step 4, image 2 of 3 HP Pavilion dm4-1265dx Hard Drive Replacement: step 4, image 3 of 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: step 5, image 1 of 3 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: step 5, image 2 of 3 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: step 5, image 3 of 3
    • Loosen the single captive screw holding the hard drive cover in place using a Phillips #0 screwdriver.
    • Lift the hard drive cover away and up to remove.
  6. HP Pavilion dm4-1265dx Hard Drive Replacement: step 6, image 1 of 3 HP Pavilion dm4-1265dx Hard Drive Replacement: step 6, image 2 of 3 HP Pavilion dm4-1265dx Hard Drive Replacement: step 6, image 3 of 3
    • Lift the hard drive out of the device from the connector side.
    • Grasp the connector and pull it out of the hard drive.
    • Remove the hard drive from the laptop.
Matthew Walter
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 415
